I got a MSD optispark which is vented to go on my 94 lt1 motor, but I can't find a 1/8" brass fitting for the intake manifold vacuum lines. Could anyone point me in the right direction?
IM Vacuum Tee Fitting for Vented Optispark Conversion
cut the line that is already there and put the T into it. Run the new vacuum line to the other side of the T. The second line from the dizzy goes to a "port" in the intake tube. I think you may have to drill a hole in the intake tube for this line. The instructions will tell you where to drill it. I have an aftermarket elbow with a port in it already,that is where I plugged mine into
every lt1 on the drivers side has 3 vacuum ports in it. if you had a non-vented opti, there will be a hope with a 1/4NPT pipe plug in it.
that is what you want. a tee is not the best solution.
the opti vent is a vent line, and does not maintain vacuum, it is actually a controlled vacuum leak, so it will reduce vacuum on whatever line you're teeing into.
Related Threads
LS1LT1 Forum
posts
551K
members
35K
Since
2004
