If ur opti is misfiring will it cause the transmission to act up the this is a96 with obd 2 and the only code showing is multiple engine misfire
Codes can cause other systems like the transmission to act up. I suggest you go to the following link and download the 96 service manual. It will have code definitions, what makes code set, and what actions pcm takes when code sets. Also troubleshooting for the code. My Files
