96 is an automatic and a guy locally has a 95 with the 3.4 and a T5 that he's parting out. He's willing to sell everything a person needs for a swap ( pedals, master and slave cylinders, bellhousing, etc ) for about $250. Question is, can I just bolt this up to the 3800? I'm assuming I'll need a flywheel at least. Will everything else work? Especially the speedometer?
The clutch release mechanism and parts changed. The rest of the trans. other than the front should be the same. Not sure what it takes to possibly use the 94 release setup/ bell on a 3800. The pedals will work.
So if I get a clutch, flywheel, fork, and slave cylinder, I should be able to bolt the transmission itself to the 3800?
