1. It was there or behind the intake under the cowl, I would take behind the water pump personally. If you do proper maintenance, you will never have an opti issue. Don't watch out for a leaky waterpump when the seals go? Well, thats not GM's fault.
2. Can't really give a good reason, the stock manifolds do suck, solution is to get some long tubes.
3. Running a dual exhaust is 99.9% cause the owner wants sound, not added performance, the 3" catback will support more than most will ever need.
