Hi. I'm 3/4 finished with my conversion and I haven't been able to find anyone to reflash the ecm. As far as I understand it's as simple as just reflashing a stock 6-speed tune. Any help would be greatly appreciated.
Thanks
Vinny
First off, we need to know year, make, model, engine of your car. This makes a big difference.
Just for f-bodies, 93 has the old removable chip that can't be reflashed. 94-95 are obd 1 cars that can be flashed with tunercat's winflash program. I believe it's $20 on tunercat sife.
Bin files of 94-95 cars can be found on the gearheadefi forum.
If your f-body is a 96-97, it's an obd 2 car and needs an obd 2 tuning program to flash pcm.
If you want to have someone else do the job, go to the following link. He does all 93-97. LT1 PCM Tuning - Welcome!
Then you will need to have someone flash it for you. Most people that I know charge $250.00 and up to do this. You can have your pcm sent off to a company and have it done if you don’t have any one local that can do it. Good luck
