moving this over here from the tranny section because it is more of an ecm question now. long and short of it is i have a 94 TA that has had motor and tranny swapped, but previous owner, but tranny just ate itself, concern is that it is running a 95 tranny on a 94 pcm, which according to frank is not good. now before i buy another tranny i need to know what year my pcm is because i am not sure if it was changed with the motor and tranny or not. i pulled the numbers off and called dealer dealer says same pcm for 94/95. but has different programming :craz28: do any of the other numbers on the pcm denote what year is flashed to it?
if you want to know more on why i need to know this read the post http://www.ls1lt1.com/forum/automatic-transmissions-%7C-torque-converters/60962-what-transmissions-can-i-put-my-trans-am.html
