one of the easiest ways to tell is this. does your shifter have a selectable first gear? as in, on your gear selector, where it says P R N OD D, does it go 2 then 1, or does it just stop at 2? If it stops at 2, then you have the 2.73's. Also, if you'll look on your options sheet, in your console, look for the option code listed as either GU2 or GU5, GU2 will be the 2.73, and the GU5 will be the 3.23's. It will be listed towards the end of the options.
