Turn signal and abs.
66 views 4 replies 3 participants last post by  TealHornet
#1 ·
I recently did a full harness swap. I swapped the harness for a 98 trans am into a 95 trans am. I also swapped in a six speed and the rear end out of the 97. I belive everything is plugged in correctly but im having problems with my turn signal abs and oil pressure gauge inside the cluster.
For the turn signals neither side works at all but my hazards work. I dont seem to have power to the turn b u fuse.
For the abs I dont have power to three of the fuses but the relay had power. The abs module seems to have power as well.
The oil pressure gauge is broken inside the cluster i think. The gauge didnt seem broken before I installed the cluster but in the middle of tightening thr bolts it shot up to the middle and when you turned the key it would go up to max. Now since the car has been driven its at the middle and shoots down when you turn the key to thr on position.
#3 ·
oil pressure gauge probably isnt hooked up its by oil filter almost in back of engine .
turn signals and brights are on top of lower steering column.
abs might be a vac line so study the vac diagram on radiator and look for plugs hanging .
Theres allways
loose ends to chase.
thats why you take pictures when you take things apart and some things you can youtube.
Shoebox .com can help too
try to take them 1 at a time you wont be so confused look in hear for downloadable pdf service manuals
http://www.mediafire.../?40mfgeoe4ctti but hurry its up and down and I think its working right now .
