1 - 20 of 425 Posts
Whistles go Whoooooooooo
Gonna throw some pics up of the current engine since its mostly all done now. :D
This is the turbo kit
Atmosphere maker :devil:
Some engine assembly pics
Cam pic
Full specs and what not will be up later.
Discussion Starter · #5 ·
If your married, your wife must be a real peach. Most husbands would be planted in the back yard if they put car parts on the dining room table.
:lol: Not married, but if you showed my mom the pic, I would be six feet under faster than my car ever went.
Gonna throw the motor in the car this weekend hopefully and yank the front bumper/fenders off.
Hopefully by spring, early summer, I will be running some nasty fast 12s. :thumbsup:
........Hopefully by spring, early summer, I will be running some nasty fast 12s. :thumbsup:
Only 12's?????
I would think that with a decent set of heads, some 3.73 gears (A4 tranny?) and a good tune you would hit 11's pretty easy.
KW
Discussion Starter · #12 ·
Only 12's?????
KW
Not sure if that was sarcasm, but if it runs slower than 10s, its being driven off a bridge. :lol:
Dizzy in back is cam sensor for PCM.
Discussion Starter · #14 ·
Not using the 24x sensor on the front?
Correct, it was cheaper to use this and I figured what the hell I have the correct intake, might as well confuse people.
Discussion Starter · #16 ·
And to throw some specs up..
Turbo is a pt76Gts, will be hopefully pushing ~15-20psi with a large FMIC and meth.
Engine is composed of a .030 over block, compstar 3.75 crank, compstar 6" rods, JE -30 cc pistons, and some ported stock heads. Of course topped off with a converted Vic E intake and a little nitrous.
Cam is a 224/224 112, should idle nice and tame to confuse even more people ;)
Discussion Starter · #18 ·
The whistle won't confuse anybody. What boost controller are you running?
It won't whistle at idle. :p
Controller will be an eboost2 or a boostleash2 if I want to run a HPA tank and tiny wastegate spring.
Nice job! Looks like a sweet build. Nice parts selections, too.
Kind of motivates me to work on mine now...!!
1 - 20 of 425 Posts
