Stock converters stall at 1600-1800.
Stall speed is estimated and it is theoretically the max speed the motor will spin while holding the car still. Usually the power overcomes the brakes before you can get near the rated stall speed, so you can't actually duplicate the stall speed in the car..its more of a bench measurement.
The flash speed I guess you could say is the same thing but due to engine power levels, etc. the flash speed can and usually does vary from rated stall speed.
If you sit at the line at idle, and nail the gas, the converter will flash up to some certain RPM before the car moves. That's the flash speed.
My 2800 rated converter would hit 3000 off the line flash speed.
