1 - 10 of 10 Posts
Been getting the "SES" light on my 94 for a couple of years.Runs fine,just annoying.
Getting trouble codes #75,76,& 77 saying all 3 EGR solenoids are bad. I installed a new EGR valve when it first started but still comes on every time I drive it.Usually as I let off the pedal to come to a stop.
Also got soft codes saying:
Quad driver 1--bad
Quad driver 2--bad
Quad driver 3--ok
Quad driver 4--bad
Don't have a clue what this is. Like I said, it runs great.I'd just light to stop the light.
Don't wanna just pull the bulb!!
Any ideas?
Thanks
3.4 car?
Yep. 3.4 with auto trans.I've been researching while waiting a reply.I'm wondering if the quad drivers are causing the EGR solenoid malfunction?
Could be. Is it the electronic EGR or is it a trditional vacuum style? Haven't dealt with many 3.4 F bodies.
Electronic.No vacuum.I replaced it a year or two ago when the problem first started. I can erase the trouble codes but after a day or two it returns.
Think I have my service manual for my 94 GP yet. Can't gaurantee I can find an answer in there but it should be close
I had the same problem on a 1994 grand prix se which had the 3.1 in it. I know its a different engine, but same problem it sounds like. Kept kicking out egr codes whenever I cleared them. I actually pruchased a couple egr solenoids trying to fix the problem. I knew someone at a local shop & had them check it out for me. It turned out to be the egr passageways were clogged up in the manifold. Cleared them out..problem never came back.
I'd clean the passages out and see what happens
quad driver codes are bad news.
if a quad driver has fails, it's possible you had a dead short in a relay or solenoid that damaged the ECM
(a quad driver is like a minature switch bank in the ECM itself)
1 - 10 of 10 Posts
