po101 is for maf performance, try cleaning maf and checking the wiring.
po131 and po151 are for the 2 front o2 sensors. They are reading low voltage. You need to hook up to a scanner and monitor your o2 readings. According to the code the readings are staying low and not fluctuating like they should be. Check fuses, power and ground to o2 heater circuit. If that is good change o2's
po171 is related to the o2 sensor. It's saying that driver side of engine is running too lean. O2 fix should fix that.
All this info on codes and trouble shooting, as well as wiring diagrams will be found in this section. Look for thread titled "GM service manual" Open thread, click link, download the 2000 factory service manual. Your 2002 shares about 99% of the 00 info.
