I recently parted out an unfinished project and the motor was sold but now is not... Buyer backed out. No worries. This motor may have a few hours total of run time. Has everything needed to make 750-850RWHP.
Specs: 383 LT1 Engine 4.030 Block, Zero Decked,
Converted to 4 bolt mains with Billet main caps
Ohio Crank 4340 3.75 Stroke Crank 2 piece rear main (double keyed)
Ohio 4340 H beam rods
All balanced.
Probe SRS 2618 Reverse dome blower pistons dish 9.0 to 1 compression
ARP Main and Head Studs
Melling HP high volume oil pump, upgraded drive
ATI BBC billet steel hub and ATI dampener
Cometic Head Gaskets
Bullet custom Blower grind Hydraulic roller Camshaft for this application
LT4 lifters
Comp Chromemoly pushrods
Comp Guide plates
Comp Pro Magnum 1.6 roller rockers 7/16 stud
Stock casting Heads, Ferrea Valves, Inconel Exhaust Valve
Stock casting Intake hand ported/port matched
Teflon coated bearings
New GM water pump
NGK TR6 plugs
Canton Fabbed valve covers
Canton Oil pan with trap doors and kickouts
$3000
PM or text. 580-678-6378
I have taken the pan and valve covers off and taken pics. Will send to serious buyers.
All balanced.
LT4 lifters
Comp Guide plates
New GM water pump
NGK TR6 plugs
$3000
