I drove my 97 Formula today and it seemed normal for the first 10 minutes. Then I started hearing a strange noise from the rear when idling (almost sounded like speaker feedback when you place the microphone too close to the speaker).
I shut down the car, waited a minute, then when I turned the key (no start), the fuel pump sounded horrible when it was priming!
The car starts and still drives fine, what should I expect if I ignore these sounds? Seems like it was on and off today, more noticeable at lower speeds. First time experiencing these noises.
The fuel pump was replaced just a year ago, and I don't think I put more than 3000 miles since that time.
Any ideas? It was quite hot and humid today, and I don't usually drive the car much.
Thanks!
Also like to add -- I opened the fuel cap and it was venting for a while. I closed it, waited 10 seconds, then opened again and it was continue to "vent".
After waiting an hour, I turn the key and pump prime sounded normal. Also started up and revved normal too.
Could it be the EVAP? I also noticed a pretty strong odor when I stopped the car but left it running for a minute.
Thanks!
