After replacing the FPR and making sure I had no vacuum leaks. I still have issues. When I crank the car up it idles and runs good then after a few minutes it starts acting up. Has a rough idle and starts cutting out and eventually dying. Going down the road you can't keep it running either. Questions
1. Could it have learned the wrong idle? My air intake elbow dosen't have the silentcer tube, I had it closed off the best I could but some air was getting by.
2. Could the plugs be fouled bad enough to cause problems.
Up for any suggestions! I'm getting disgusted with it. Need some help. :angry:
