1 - 20 of 21 Posts
Why would a starter still spin after the ignition switch is turned off and the key is taken out. My 79 trans am just developed this problem. It's only a 2 year old rebuilt starter. Today, while up in the mountains, in the middle of nowhere, I shut the car off to let my dog outside for a bit. When we got back in I cranked it over, and the starter and engine just kept spinning, without firing, while the key was in "engine on" position, and with the key in "off" position, and with the key out. I've read from other people that a solenoid going bad, or getting stuck will cause this, but why would it continue to draw power and engage the gear when the ingition switch that supplies power is turned "off"? I would figure, one there's no power coming down the ignition line to the solenoid, there would be no more problem. So, I was thinking of replacing the starter switch in the sterring columb. But, now I'm uncertain. Can anyone explain how the solenoid continues to get power when the key is off?
Thanks
Even though you have turned your key off, if the switch inside the solenoid is stuck on and is allowing power to flow from the big lead coming directly from the battery, to the big lead going to the starter motor, it will keep spinning, as long as, the switch allows power to flow. So let me explain, when you turn the ignition switch to start 2 things happen, the solenoid pops out allowing drive gear to turn motor over and (2) theres a switch in there that allows power to flow from batt wire to starter motor wire. If that switch doesn't disengage when you let off the key and go to run or off position, your starter motor will run til the cows come home, or at least till the batt goes dead or the starter burns up as these motors are made for strictly intermittent use. This is because if the switch is stuck the starter drive stays engaged also. Of course you need to check out if the purple wire to the solenoid is getting power after the start position is released on ignition switch. You can hook a test light to purple wire with long enough wires to see from drivers seat. Every time you go to the start position the light will turn on. See what the light does when starter runs on. If light goes out when starter runs on, its the switch in the solenoid. If light stays on when starter runs on, theres something amiss in the ignition switch, ignition lock, wiring department.
Coco is right. Let me explain a little bit further. When the ignition switch is turned to the start p[osition and the purplewire is energized, the solenoid pops out and when the ignition is released the solenoid rod SHOULD pop back down( a spring assists this). If the solenoid rod sticks, the switch inside the solenoid assy will stay in contact letting the starter continue to spin.
When you test the purple wire remove it from the starter.
I solved a similar problem by replacing the starter and solenoid. As I recall, the actual problem was with the bendix drive--actually the fingers that move the bendix to the fly wheel. The ends of the fingers were worn, and they did not retrieve the bendix gears from the fly wheel.
My 95 z28 is kind of having the same issue except it stays going for a bit while the engine is running and for a couple secs after I turn the key off. Im just hoping I haven't busted some teeth on the flywheel.
Flywheel is very robust. I doubt that you have sheared off any teeth. (My gut feeling--or wishful thinking.) People hit the starter button all the time while the engine is running. They survive.
I would not worry about the flywheel. Rebuild the starter if you have not done so. Take a close look at the fingers that move the bendix. Might need to replace that part of the starter also. Brushes and bushings for starters can be hard to find. I usually go to a shop that rebuilds starters and horse trade them for a dozen tacos.
As others have said, look at the solenoid. Once you have the starter down, replace the solenoid also. Do all the work now; avoid another down session. This is gonna be a hot summer.
Yea. I'm taking the starter to a shop that rebuilds them. It's way cheaper and better in my option than buying out right new. Picked a horrible time to go out tho. Just spent almost $800 in a new clutch install. Scared me tho. Strange noise came from the bell housing. I thought my clutch was bad again. took it back to my mechanic and he determined it was the starter. I worry bout the flywheel due to it making the noise while I was still 2 blocks from his shop. Arrived and turned the car off and it didn't start again.
Discussion Starter · #9 ·
For the hell of it, I took the starter to a shop today and had it tested. It came back fine. They told me it was the switch mounted on the bottom of my steering columb, under the dash. So, now it's time to test wiring to find out if it really is the culprit. or, just pay the $15 and replace the switch.
Algermilitia, its been a year since you posted up your starter problem. You mean your just now getting it taken care of? I thought I was the king of procrastinators.:lol:
Discussion Starter · #11 ·
I've been fixing my car first. Been experimenting with tuning the computer for the last week. But, now I need to move on to this car. It won't start, just keeps cranking after you let off the key, and I need it up to the garage to begin the engine rebuild. I could get things done quicker if my schedule wasn't so screwed, or we had a garage we could put the cars in. But, my day starts at about 1pm to 4 or 6am. When I get home, it's always dark and often wet. Days I can work on the vehicles are very limited. On top of that, I try to spend as much time as I can with my folks since my father's health is failing. So, I end up only working on the vehicle for a few hours and then the rest of the day with them. So, yeah it takes me awhile...
Since you've taken starter in and proved it was good, your electrical part of the ignition switch, or the rod that connects lock cylinder to elec part ign sw are about the only suspects left. A short in the wire to the solenoid wouldn't cause it as that wire gets no power on it until ign sw put in start position. If you had a problem with either the clutch start sw for manual, or the trans position sw for the automatic, then car wouldn't start at all. Same with tdr, a problem with it would cause a no start condition. So as Sherlock would say to Dr. Watson " when you've eliminated all the other possibilities, what your left with is the truth."
Discussion Starter · #13 ·
Yeah, I'll be checking it out this Friday, and probably replacing it just for the hell of it
Discussion Starter · #14 ·
Ok, the update... and it's got me stumped at the moment.
I replaced the ignition switch. Easy job. I tested for power at the solenoid wire. Power on with key, off when key is off. Perfect. Hooked up starter, but left it off the engine. Everything worked perfectly. Installed in the engine, and problem still persists! WHAT?! Pulled it out and checked again... now it's working fine, again! Back on engine... PROBLEM! I hooked a test light up to the solenoid stud. No power is going through when the key is off, just like it's supposed to work! Turn key to start, full power is coming through the test light. Turn key off, a small amount of power is coming through the test light still, and the solenoid is still engaged. Disconnect battery, solenoid disengages and no power is detected in the wire after reconnecting battery. Hmmmm....
So, what could cause power to continue feeding the solenoid after turning the key off, but only after sending power to the solenoid to begin with? And, why does that power disappear and not come back until the key is turned again after disconnecting and reconnecting the battery?
Any ideas?
Since the starter works fine when hanging free, then messes up when attached to engine, as Sherlock Holmes would say, "When you've eliminated all other posibilities, then the truth is what is left". You have a problem with your starter's pinion gear mating with the flywheel. What is happening is when you hit start the pinion gear slides out an engages the flywheel teeth. Normally when you release start, the pinion slides all the way back. As background when pinion starts to slide out, the contact in solenoid closes and sends power to starter motor. If pinion does not slide all the way back to home, the switch in the solenoid is still making a little bit of contact. Thus the weak test light when ign sw goes from start to run. You need to find out why pinion is hanging up on flywheel teeth. Adding or subtracting starter shims might solve your problem. Or maybe a new flywheel or flex plate is in order. Or maybe the starter mounting spot is wacked out.
Discussion Starter · #16 ·
Ok, the next dry day, I'll will go out and loosen the starter, and then gradually start tightening it until it gives me the trouble again. Since it's a rebuilt, perhaps no shims are required anymore.
Discussion Starter · #17 ·
Pinion gear is getting stuck in the flywheel. I've tried shimming it more, to make the contact between gear and flyweel a little looser, but even after 10 shims, it's still sticking. It's making me think that the gears can get stuck by overshimming. Don't know if this is true, though. Maybe one of you can shed some light. If it isn't true, then I have a problem with the spring in the solenoid.
If you had a spare starter, you could test it to see if problem persists. If 2 starters do the same thing its the flywheel or flex plate. If 2nd starter works correctly, its the starter.
I experienced the same problem and after reading your post ,l bought a selenoid ,fitted it and it now works perfect.Thanks a lot
1 - 20 of 21 Posts
