Well In my personal opinion, Your really not supposed to go through deep puddles or water with with an LT1 bcuz of the opti spark (as you know) Thats why Ive never seen an LT1 in a sand rail or dune buggy or mud crawler.
I would possibly suspect the opti spark and also the ICM. If you put those cables on backwards i could imagine it shorted something out in there.
Have you tried to run it for codes?
Where is it leaking oil at?
Also If the MAF was disconnected like you said that would help to explain the surges dies , surges dies, surges dies. Bcuz the engine is trying to figure out how much air is going in there for the fuel ( i think)
I think (if) the MAF was causing this and you just sit in your drive way and maybe crank it and try and keep it running then it might smooth out after a while because itll figure out the right mixture with the MAF re connected.
MAKE SURE that MAF hasnt been de-screened.
