Hi all,
Im looking to upgrade my brakes, already have the Corvette front rotors and pads as well as the conversion kit but now im looking for brake lines all around as ill be tracking this thing hopefully soon.
Im curious to know what you guys use or suggest.
Thanks in advance
Nick
Unless you like the look, these are not needed. I've never had a regular oem type brake hose fail on me. But I change them every 6 years just to make sure.
Do you also track your car on a road course? The plan is to track this a couple times a month. Im curious because if you do and the stock lines don't overheat and work well then ill probably just keep using stock ones. I ask because after doing some research it seem like many people suggest upgrading to keep brake fade to a min.
I didn't know you wanted to do track time. Didn't pay attention to the tracking part of your post.
In that case, go for the best hoses you can find.
Ahh thanks man!
