Rich running doesn't cause headers to turn red, unless it's so rich unburned gas is going out the exhaust valve and burning at the header. But if it's running that rich, your probably getting bore washing and the damage that goes with it.
So I would lean towards very lean running. I lean this way because with the heads & cam setup, I believe your stock injectors and pcm tune are not up to the task. Add sluggish o2 sensors to the mix, some vacuum leaks and you have a very lean running condition.
Also beware that running lean enough to cause your headers to turn cherry red at idle, can melt your pistons in short order.
As stated in the other post you have, pm me with your e-mail address and I'll send you the pdf file of "sensor readings and what they mean.
Also since you are using DataMaster, you can upload the scan file to a file sharing site, then link it to a post, where members can review your data log and help you determine the problem.
Your mechanic is right about the mods causing pcm to need a tune. You could get tunercat and learn to tune yourself, but since you don't know what sensor reading mean yet, I suggest sending pcm to a tuner and have him do the job. You will have to fill a form out with your engine mods, he might want to look at a couple of your DataMaster log files also.
Tuners at LT1 PCM Tuning - Welcome!
PCMforless
madtuner.com - Home
PCMforless
madtuner.com - Home
