1 - 12 of 12 Posts
Just seeing how many votes I get for leaving the load release springs out. They are not in now but I know the guy i'm going to have look my Trans over is going to tell me to have them in.
How is the 3-4 clutch stacked? What setup is in there...?
I'd definitely leave them out in an F-body where you're trying to shorten the shift time a little more than in some other applications. I'll reuse them in a truck transmission as long as they're in good shape, but if they're no good, I just leave them out and move on...
Make sure you're putting a good setup in the 3-4, though...
We don't put them back in anything. They cause a delay on the 2-3 shift. We have tried just about every 3-4 set up out there. The problem with the Z-Pak and Alto 9 disc set up is that the steel material is too thin. This makes them much more prone to warping. We set them up with stock top and bottom pressure plates, 6 .077" Kolene coated steels and 7 Borg Warner High Energy frictions.
Frank
Since I have to keep the zpak in there, will it hold up to a stock engine? What would your set the clearance to?
The Z-Pak failure isn't horsepower related. They will warp up just the same behind a stock motor as they will behind big horsepower.
Frank
Will anything help or do I just hope they hold up. Is it heat related? I have the stock Trans cooler and an external cooler also.
"Normal" transmission heat will warp them. My best advice is change them while it's apart.
Frank
Spelling Bee winnah!
Dynamic and Cahall are right. When it's out change it. Take it from me as well, it will fail even under normal driving conditions.
I stack my 3-4's pretty much the same way Frank does. It's interesting how his 2-1/2 decades of experience and my 2-1/2 decades of experience have brought us to nearly identical setups...
I use a 7 disc stack on EVERY 4L60E (and 700R4) that I build. I use new OEM AC Delco apply and backing plates (.225" and .192", respectively), seven .080" high energy frictions (Borg Warner or Raybestos) and six .076" steels. I use kolene steels in anything extreme-duty or high-performance and standard steels in most of the daily driven truck builds. With a "7" apply ring and a .093" snap ring, this will stack up every time with about .025-.030" clearance, which is just about perfect...
Nope, nope, nope. I do it different! I use a .190" pressure plate, instead of the .192"...LOL. Seriously, though... Isn't it funny how something so simple works better than all those "Performance" 3-4 set ups?
Frank
I know...! Sometimes the simplest, non-glamorous setups produce the best results. I have customers who absolutely torture their 4L60E's and that 7 disc with kolenes just puts up with it...
1 - 12 of 12 Posts
