Thanks again to Mike Horist from LS1tech.com for this valuable tuning information!!!
Quick Links:
Learning to Tune:
--Tuner Software-Tuning 101|
http://www.ls1tech.com/forums/showthread.php?t=284479
--HP Tuners .bin Repository|
http://www.ls1tech.com/forums/showthread.php?t=190486
--Predator Tuning 101|
http://www.ls1tech.com/forums/showpost.php?p=2652650&postcount=10
Fuel Trim Cells:
--Fuel Trim Cell Discussion|
http://www.ls1tech.com/forums/showthread.php?t=125583
Injector Tuning:
--Tuning SVO Injectors|
http://www.ls1tech.com/forums/showthread.php?t=326601
--Injector Scaling Calculations|
http://www.transamws6.net/HPTuners/injectors.xls
--Injector Duty Cycle Calculations|
http://www.ls1tech.com/forums/showthread.php?t=306296
MAF and VE Tuning:
--*NEW*How the MAF Works*NEW*|
http://www.ls1tech.com/forums/showthread.php?t=363392
--MAF Table Tuning (Dialing in the MAF Table)|
http://www.ls1tech.com/forums/showthread.php?t=256989
--VE Table Cracked!|
http://www.ls1tech.com/forums/showthread.php?t=149741
--VE Table Tuning -- Now Hesitation when driving|
http://www.ls1tech.com/forums/showthread.php?t=84933
--Tuning VE via fuel trims|
http://www.ls1tech.com/forums/showthread.php?t=304025
Torque Converter/Shifting Tuning
--Torque Converter locks/unlocks after larger converter install -- FIX|
http://www.ls1tech.com/forums/showthread.php?t=162767
Idle Tuning:
--Stop drilling those Throttle Bodies!|
http://www.ls1tech.com/forums/showthread.php?t=177230
--Idle Operation Part 1|
http://www.ls1tech.com/forums/showthread.php?t=193103
--MAF and Running Airflow Tables|
http://www.ls1tech.com/forums/showthread.php?t=290064
Diagnostics/Troubleshooting/Other:
--Service Engine Soon (SES) Lookup and Diagnostics|
http://www.ls1tech.com/forums/showthread.php?t=209783
--Detailed Diagnostic Information|
http://www.ls1tech.com/forums/showthread.php?t=103710
--GM Driving Cycle (Completing OBDII tests)|
http://www.transamws6.net/HPTuners/gm_driving_cycle.txt
Quick Links:
Learning to Tune:
Fuel Trim Cells:
Injector Tuning:
MAF and VE Tuning:
Idle Tuning:
