so i got a Ram Powergrip from TSP a few months ago. also purchased a new slave with it as well. well, i never got around to installing it so it was just sitting around...
months went by and my friend bought a SS from a dealer, which ended up needing to have the tranny repaired under warrenty. while the tranny was out, he wanted to replace the clutch, so i told him to toss in the Ram i had lying around.
the dealer put it in, along with the new slave. but something was not right. when pushing down the clutch pedal, is was 'dead' until it was right off the floor. and when disengaging the clutch, its disengages immediately, and then is dead after an inch or so off the floor. the lines were bled multiple times, so that wasnt an issue. also a shim was put it, and it helped a little, but not enough to make it drivable.
the dealer thinks it might be the wrong clutch, but on the box im pretty sure it says it the right one. he held it up to the stocker and it wasnt the same size (off by a little), and i want to say some holes were off as well. he ended up putting the stock clutch back in and it works fine.
did i just get the wrong clutch? or was something not done right?
