Are you having cooling problems? The best mod I made to my 88 Iroc that had factory dual fans was to remove them both and install a dual fan assembly from an LS-1 car. These fans are shrouded very nicely to force all the air they pull right through the radiator. It was literally a drop in deal with very little mod required. With a 170 thermostat and my fans programmed to come on at 180 I can sit all day in traffic and the A/C blowing cold with no worries. The stock fans would not allow this,,,after a while the temp would creep...the stock fan assembly sucked in my opinion with literally no shrouding. I still run the factory issue radiator in mine. Larry.
