Hey Guys,
So I am looking to make a change to my Wheel/Tire Setup for a little more of a Drag Setup. This is what I am looking at running:
Dark Stars
Front: 17x4.5 w/ tire not sure yet
Rear 15x10 w/ 295/55R15
I have to run a 17" wheel in the front to clear my Baer BBK which Im okay with but I am just curious if the 1.75" backspacing will be an issue.
I would run the rear with a 7.25" backspacing which seems to be okay (typically i see 7.5") I was wondering if anyone was running a similar setup. I would appreciate any input before I go ahead and pull the trigger on these wheels/tires.
Thanks,
Erik
Im in the same boat u are id rather run 17s all the way around but they dont make the bolt pattern in a 17" thats 10.5 wide
Ya I see that. I have no problem going with a 15 in the rear since it works for the tire I want I just need to know if the backspacing for the racestars will be okay to work with. not too much tuck, but not too much poke.
