Ok havent been on here in a while. Been on LS1tech getting all sorts of info for turbo LQ4 build. But I know this is the spot for LT questions. So I'm hoping bobdec and others step in.
I'm still torn on doing nitrous LT or turbo LQ4. But anyways, with the Accel Pro Ram intake on the LT,
1. With tuning the codes out could I still pass emissions using a "old school" distrubutor? I would imagine it still would because maybe the crank sensor will still pick up RPM's, and I'd still be using fuel injectors and rails, with the throttle body mounted in place of a carb.
2. Where would I buy one of these. I see Tanner is using one on his LT camaro. But I cant seem to find one. Found one on ebay, but no fuel rails.
3. I hear it has to be modified to fit. What has to be done to make it fit, use a distributor, and throttle body.
