Calling a moderator a dummy on this forum, & calling an administrator on the firebird nation a dummy, isn't doing you any good.
Yes, I recommended checking the battery because many people don't think to check that. When a person posts, we have no idea of what your knowledge level is. So we usually post the simple things first.
If your car goes through the programming procedure and fob doesn't unlock the door, what test have you done to make sure fob is good?
The programing procedure you listed didn't involve the fob until you tried to unlock the door. So wise guy, I ask again what test you used to make sure fob was good.
On my 95 trans am, the programming was a little bit different than newer models, but basically involved the same steps. Fob was doa and door locks still don't work as fob for 95 is very hard to find.
Your lucky I'm in a good mood today. Normally when someone calls me names, the ban button comes out.
