So I had some money again and started buying up some more parts for my toy. 1995 z28 with a stroker. I bought a powermaster xs high torque starter to deal with the extra load of the 383 compression and the rear mount battery. I have upgraded cables for grounds and power already. When I removed my starter to install the new one I found the starter pinion gear and the flexate ring gear are touching without throwing out the pinion. There should be attests 1/16 inch clearance according to powermaster. I got the right part number starter the 9502. Has anyone else had this issue?? If so how did u fix? I called powermaster about a possible shim but haven't gotten a response yet. Thanks as always guys. :LS1LT1flag:
