Power locks not working. Help please
1361 Views 5 Replies 4 Participants Last post by  Perry
Hey I just picked up a 93 trans am and the lock switches don't seem to work. I made sure the wiring is attached at the switch and the fuse is good. Any advice?
It is most likely your Keyless Entry Module I believe it is located behind the kick panel in the passenger floor board (that's where it is in my 94). It is a little black box with 2 connectors going into it. Take it out and open it up and it will probably be corroded or missing completely. You can get a new on from tacreations for about $27 shipped.
Thanks I will check that out today
If it's not that check your power relay located under the center console.
Another thought- both switches share the same ground wire that's on the pass side switch. That was my problem.
Problem solved. I found 2 disconnected wires passenger side kick panel. All is good now. Thanks
