Replacing the original power antenna.
Want to know the pinout of the 3 wire connector, and if I can wire the new one in without splicing.
Thanks
Thank you my friend.
Any suggestions on extracting the pins from the old antenna so I can solder the new leads directly to the pins?
Would prefer that rather than splicing with 3 butt connectors and shrink tubing.
Your thoughts?
Go to the link I posted and download the 94 service manual. Then go to the electrical section 8. Starting at the bottom of page 8A-5-8, there will be instructions on how to remove connector pins from the connector.
If you mess up a pin or connector shell, new ones can be bought on ebay & other internet sites.
