What is a good brand of plug wires for a 97 Z28 Lt1 with pacesetter long tube headers. And do you know the part number on them. Thanks
Just as long as you stay away from the cheap bargain sets, most any of the major brands will work. If your planning to reroute the plug wires to over the valve covers, I suggest a cut to correct length set of plug wires. If you plan on routing them to the stock positions a standard set for your 97 z28 will be fine.
I've had good luck with Taylor wire sets, and they are not expensive. They are easy to find, just Google.
Al in Tucson
