Does anybody know where I can get my pcm reprogrammed in northcentral Wisconsin? I need emissions removed, vatts, and a performance tune installed/reprogrammed! The only thing I pulled from this car is the air pump so far.
Also, these are the codes that I was given from a shop.
51 ECM Prom Error
53 System Voltage To High
27 EGR Electrical Fault (QDM)
26 Evap Purge Circuit
29 Secondary Air Injection Pump Circuit
77 Fan 1 Fault
I've tried two other pcm/ecm units with the same results each time!!! PLZ help!
51 ECM Prom Error
77 Fan 1 Fault
