1 - 9 of 9 Posts
As the title states, I have a P1661 (malfunction indicator lamp fault) code popping and I can't put my finger on what is causing it. Has anyone seen this, and hopefully know of a reason that this code would pop? Thanks in advance...
Discussion Starter #2
nobody has any ideas?
Basically, this code means the PCM detected a fault with the MIL circuit, as has already been discussed here.
If there was a fault in the circuit that detects the fault, however, that might cause a "false positive" for this code.
If the circuits check out, the factory service manuals say the PCM needs to be replaced (the fault detection circuits are internal to the PCM)...
Discussion Starter #6
Thanks man, does the manual give instructions on how to check for a fault in the circuit that detects faults?
Discussion Starter #8
thanks man, I appreciate it...
1 - 9 of 9 Posts
