Will a 95 LT1 PCM work on a 97 LT1?
actually changing the knock sensor is a 5 min task....Would the knock sensor swap be something that can be done by a dyno shop? What is the significance of OBD2 vs OBD1?
knock sensor will have nothing to do with emissions...Would switching to an OBD1 knock sensor make is easier to pass emissions inspection?
Other than the coolant that will come fire-hosing out of there when you pull it, yes, it is a simple job. But, the knock sensor doubles as the block drain plug on that side...actually changing the knock sensor is a 5 min task.....
