So I've had to drastically change my LT1 set up due to a bunch of problems the 93 LT1 motor I bought has. I was originally just planning on putting a cam and supporting mods in that motor and running it. But it's cylinders are so eat up with rust that now my builder and I have just decided to bore the original lt1 from my 1996 z28 (since its cylinders are also in bad shape) and rebuild it.
I didn't really fit pistons into my budget and I've been dying to hear this thing running for over a year now so I just bought some cheap Speed Pro hypereutectic pistons for now. I just dropped my block off at the machine shop yesterday and they said it'll be 3 weeks until they get it done. So that will give me time to buy new rods as well. Here's a list of everything of my build. What do you guys think?
355ci 11.4:1 comp
Speed Pro H631CP .030 over pistons
Scat I beam Rods w/ARP Bolts
Lloyd Elliot 232/240 .578/.574 110 LSA camshaft
Scorpion race 1.6 roller rockers
Lunati dual valve spring kit (rated to .660 lift)
.026 Head Gaskets
Single roller timing chain
Pacesetter longtubes and y pipe w/cutout
CSR electric waterpump
3.73s
3600 stall
Trans cooler
Tune by PCMForless (maybe)
Poly motor mounts
Line lock
Weight reduction: AIR, EGR, A/C, ABS, sway bar, spare tire, back seats, battery relocation, etc
I know the cam is pretty big for stock heads but we are going to clean up the bowls and everything a little on the 96 heads until I can send off the 93 heads for a LE2 set up. This is my first ever build so let me know what you guys think! Anything I should change up or not. Thanks for reading.
355ci 11.4:1 comp
.026 Head Gaskets
3.73s
3600 stall
Trans cooler
Poly motor mounts
Line lock
