I'm in the middle of replacing my intake manifold gaskets to repair an oil leak and thought it might be a good idea to make sure the oil sender isn't leaking as well.
I applied Permatex thread sealant (with PTFE) on the threads of the elbow that screws into the block. My concern is when I tighten the elbow to snug the elbow won't line up properly for the sender to clear the manifold. As it sits right now its approximately 180 degrees out of wack when tight. When I backed it off so it will line up correctly it is still somewhat snug but I'm just not sure if it'll be snug enough not to leak under pressure.
I can't imagine the frustration I may have once I button it all up just to find the oil pressure sender leaking. Any thoughts on this? How good is thread sealant when under the strain of oil pressure?
