Oil Pan Gasket Replacement
5.1K views 7 replies 3 participants last post by  93B4C
#1 ·
Well i screwed up! When replacing the rear main I tore the oil pan gasket. Is there a way to replace it without pulling the engine? What is the best procedure if so?
#8 ·
I had to remove the housing that holds the rear seal because where it mates to the block was leaking, that's how I broke the gasket. I already had the tranny out, I didn't even take the pan all the way down and was able to replace the gasket I just fished it down in the pan and then up over the pickup tube. It took me about 45 mins to fish the gasket in but I finally got it.
