For all that have stroker engines with aftermarket pans that don't seal well, here are some aftermarket pan reinforcements that work. These solve sealing issues in the area of the missing bolt hole on the passenger side of the pan for the block. This bolt hole is'nt included in some pans because of the amount of material removed from the block for the stroke. how many others have had this issue with aftermarket pans?
Discussion Starter #2
Sorry, I meant missing bolt hole on drivers side of aftermarket pans, such as this model for up to 396 strokers
Thanks for posting this info. I'm sure members with stroked engines will find the info very helpful.
Thanks for responding. I was sure other people were having this same problem, because the reviews from oil pans for stroked engines mostly had this common complaint.
