I believe the problem is in the o2 sensors/ harnesses to my 94 z causing it to run funny.... Is it possible to run a 94 z without the o2 sensors and it run fine? Any thoughts, or anyone tried this?
I'm sorry, I don't understand... Can you add more to that statement? Thanks
Admin
If you unplug the sensors (or the computer detects a problem with them) the car will not go into closed loop (mode where it uses the sensors) and it will just run off of the MAF sensor like it does when its cold.
You can run it to see if that is the problem, but I would not drive it for long like that as you will lose gas mileage and can potentially damage your cat (if you have one).
