I am in the middle of doing a V8 swap to my 2001 GMC Safari. I'm sure this questions going to show my ignorance but I am trying to take out the old fuel injectors from the LS1 fuel rails. I have removed the metal clips I only find that the injectors will spend but pulling them out you're not so much is there a trick I can't imagine getting crazy with pliers or some sort of pry tool.
O-rings on the injector hold it at both ends. Pulling them out, once metal rings are turned to correct release position takes some force. Consider that injectors have probably been in there since new.
Don't forget to use new o-rings when installing them.
And, welcome to the forum.
