hi guys I have a 1995 Camaro z28 auto tranny. So this has been a problem for the last few weeks. I bought two new optis the second opti started the car after I cleaned all grounds made sure all fuel injectors were pushed in right. so I put the car all back tg. and bam! no start so I took the car apart I decided to just pick up a new icm and a new coil and opti harness.. connected it all CAR STARTED!. this was lastnight. went to put the car tg again and bam no start my head is spinning. I got strong spark coming out of the coil so im sure the icm and coil work. I also have a spark coming out of the opti. ( the spark should only spark every 360 degree rotation of the crank shaft correct) ? because the only thing I noticed that is different is coming out of the opti I pulled one plug and held it close enough to opti to see the spark. and it will spark every second or so its not rapid.
thank you any questions or anything I dident make clear please point out im looking for help its hard to explain thank you!
