Got my heads shipped off for the le2 head cam package this is what I got so far. Wanting to know if there's anything I'm missing that I will need. This is my first time tearing a car apart advice would be much appreciated.
95z m6 156,000 miles
227/235 .565/.579 110 LSa camshaft
- Comp 1618-16
- Comp 850-16 lifters
- Comp 7938-16 pushrods
- Comp 4502-16 rocker studs
Manley 2.00/1.56 6000 series valves
Patriot Gold Extreme springs (155 lbs seat and 400 lbs open)
Steel retainers and locks
205 cc intake port
milling, cleaning and assembly
flow about 275/190 CFM
FUEL.
RACETRONIX 255lb fuel pump kit
36lb trick flow fuel injectors.
OIL.
MELLING 10554 SBC Std. Volume Oil Pump w/3/4in Inlet.
Stp oil filter.
Mobile 1 oil
GASKETS.
Felpro 1406 header gaskets
Felpro ms 95580 manifold gaskets
Felpro oil pan gasket
Felpro 45956 timing cover gasket set
Felpro 1074 head gaskets.
SENSORS.
Acdelco oxygen sensors 19178930
Ac delco icm 19352932
Ac delco oil sending unit 19344519.
Lunati timing chain set
msd spark plug wires.
Otvc wire kit.
Msd coil
Petris optispark
Egr block off plates.
160 thermostat
Duralast fuel filter
Prothane motor and transmission mounts
Coolant ect.
Xs power headers, off rd y.
New coolant hoses
New heater core hoses assembly
New heater core
New ac compressor.
This is current bolt on mods car has.
Moroso c&I
TB coolant bypass
Flowmaster 80 muffler
Cat delete
Air foil
Tune by Brandon Strong
Also is the oil pump drive and distributor drive gear the same? Which replacements should I go with? The Melling oil pump I got came with a shaft should I use that or get a OEM?
