So I have a 96 lt1 t/a and the clutch pedal is super stiff I mean solid like a rock i even desconected the slave at the tranny to try and push in the rod no luck im wanting to believe its just a bad clutch cylinder wondering if any has had this happen before and have fixed it? Thanks in advance.
The most common cause for the stiff pedal is the line between master & clutch cylinder being collapsed or blockage in line.
Unless you know age of master cylinder, line, & slave, I would replace all of them.
But just to be sure pedal assembly isn't frozen, when you remove hydraulic assembly, make sure clutch pedal moves freely.
And welcome to the forum.
thank you for the greeting and also for the valuable info my car buddies kept saying my clutch went out and I recently changed my z28 clutch and kinda didn't want to get into another clutch change but yea I looked into it their 136 brand new at summit which I think ain't all that bad Imma try and get me one this weekend and slap her on
Before you order the new clutch hydraulic parts, do check and see if the clutch lever in bell housing is frozen. Even though it's a long shot, your new clutch parts could be frozen due to damage or incorrect assembly.
I take it clutch worked after changing it?
