I seen in the Jan 06 GM High-Tech. In the write up on the 94 Z28 called Juiced. They say stock Lt-1 bottom end and heads, But with an LT4 intake. I thought that the LT4 intake won't bolt on to LT1 heads or is there a way it can be done?
It has to be machined and spacers used everything then port matched. Not an easy task.
Nate
Chris89gta
It will bolt on, but it will not work very well b/c the ports on the LT4 is a raised runner port, meaning the ports will not line up and there will be a ton of turbulance...
