Instead of spending $1500-$2000 At efi connection . How can I cheap out on this swap ?
BTT, You are thinking along the right lines with wanting to rid yourself
of the optispark,however the opti often gets a bad rap. There are plenty
of LT1 cars on the road with 100,000 miles plus on them. I use the Bailey
engineering system which converts the LT1 to a multiple coil system and
removes the high tension duties of the opti.When its all said and done you
could probably make the change for about $750.00. ed
Dynaspark
Get one for $600.00, rebuilding if necessary for $125.00..will rev high
and works well..
Whistles go Whoooooooooo
Repin your LT1 harness on your own, source a PCM and coilpacks on your own, leaves you just having to buy the cam sensor and crank sensor hardware.
^^^This...
I built my own harness, had my own coils and built my own coil brackets. I think I'm into EFI Connection for around $800, including the PCM.
