Not hardly. The engines are completely different (even different firing order) and so are the parts (except for the lifters).LT cams have a little doll pin that runs into the optispark thats why you can't use one
......and valve springsNot hardly. The engines are completely different (even different firing order) and so are the parts (except for the lifters).![]()
Yeah, the springs will fit, but they are not the same part number as the lifters are.......and valve springs.
You lay a LS cam and a LT cam side-by-side, and you'll see immediately that the LS cam will not even fit in the LT engine......won't even fit.
KW
IndeedYeah, the springs will fit, but they are not the same part number as the lifters are.But, we're both right.
Like snm saysWhy would you need to put in a LS cam?
You can have AI or LE grind you up a custom cam if you don't like the selection of cams.
