Hi guys
I'm getting some Injectors which come with LS data for the injector Voltage offsets.
Which column of kpa data do I use for the injectors going into an 95 LT1 motor
Thanks
Mitch
Since no one has helped you, may I suggest a PM to Steveo. He is into this type of info.
Or, you could try the gearhead efi forums. They're big on injector and pcm tune info.
Hi
I’m already on there.
Kur4o has some patches to remove the vacuum line reference off the fpr and use the full returnless fuel system data.
I’d like to get everything working again before I take that leap.
Cheers
Mitch
