Can you scan it and send it to me? I'll PM you my email address.It came with assembly instructions even though it came assembled so I can get a decent idea of what things are from that but its not a schematic as much as colored pictures showing where to solder certain parts to the board and places to verify voltage before its fully assembled.
Making any progress?Let me know if you don't get that or have any issues with the scans I took but I just sent it, thanks again for the help.
Send me a link to it. A storage scope just stores the waveform so you can see it later OR lets say the waveform is very slow. This waveform takes a few seconds to cross the screen. The start of it will be gone before you can see the end. So you store the waveform. It's the only way to see one complete sweep. By now I've probably confused the heck out of you. Back to what I said before. 99.99% of any problems in the Opti should set a code. Do you have a half decent code reader that works on your car? A 94 Z28 is OBD1. Don't know about 94 but my 95 has an OBD2 connector but is actually OBD1. Had to make an adapter to get my OBD1 scanner to work. I use TunerCat for some stuff on my car. Made the cable and downloaded the program. Had to get a USB to Serial adapter to make it work with my laptop. TunerCat has a very large following, lots of information on the web, and videos on youtube.From what I understand about how that works is when you hook up the leads to the wire that you want to test the signal for like any other scope but once you get the signal it can be saved on the computer and I guess you can then look up your specific car in the software and it will give you an example of what a normal signal should look like so it can be compared against the one from the car that was tested. I guess it has 8 channels which seems like alot to me but more is better than not enough. If you have heard of this type of thing let me know if it seems like it would be worth a try for I think $110 on amazon and other places but I noticed it on amazon.
Followed the link. Some of the items they were using for the various tests do not come with the scope. Did you notice the 20:1 antenuator? That divides the test voltage by 20. Keeps from blowing the input to the scope.I noticed that too and I think it is a mistake. I want it to be able to test as much as possible if my opti stuff tests out to be fine. This is a link to there website where it has more specific's Hantek1008A - Hantek Electronic & Your testing solution provider From what I noticed it has it listed as, input DC, then it says input max and there it mentions DC+AC volts
All good just don't hook it to anything going to the coil.ok well I ordered that and as long as I have what I need for the first few tests I want to do on the opti wires that I was trying to test last, I can always order the other accessories as I need them depending on what happens with those tests. I will post when I get it and have a chance to use it, hopefully I will have some useful info from that and can start to fix things rather than tracking down the problems for a change.
