21 - 37 of 37 Posts
The heads are not your problem. I said in my previous post and so have a few more people. Torque converter, and looks like they shut it down early. Looks like the graph was still on it's way up when they shut it down.
here is my email I semnt back to jamie
really no idea why the #'s are so low.
What you are seeing below 4500 RPM is converter flash. It happens with auto trans and stalls. The stall converter multiplies the TQ and makes the rear wheels see more TQ than the engine produces. This is why auto cars launch harder than 6 speeds. From 4500 RPM on up is the actual shape of the HP/TQ curves and the actual #'s the engine is making other than the basic HP/TQ being robbed from auto trans and stall.
If you have a GOOD converter from Yank or Vigilante, A 6 speed car would only be 20 HP/TQ better across the board but if you have a TCI, B&M, Fuddle, Pro Torque, etc, converter, they will rob even more HP/TQ than this.
If the converter is un locked, it will rob even more power.
Soma data logs that show AFG's, L/R O2's, L/R BLM,s timing tables, TPS, A/F ratio, Knock Retard, etc at each RPM would really help.
You can see it is a a lil rough up by 6000 RPM and might be floating valves (rockers too tight, etc), or ot could be running out of fuel, going lean, ignition problems, etc. Lots of ways to lose HP with a fuel injected set up.
The cam is made to peak around 6300 RPM and that is about where it is doing this but that doesn't mean there is not more to gain by fixing the A/F, rocker adjustment or what ever is causing the graph to get rough above 6000 RPM.
Lloyd Elliott
972-617-5671
Elliottsportworks.com
Discussion Starter #25
Thanks alot lloyd, i'm going to make the proper adjustments like you said if need be and get it to the track, i'm looking to trak 110+ like you said and then i'll go from there, also if the rockers need to be adjusted what setting would you recommend ? thanks for the feedback again lloyd. Once again great customer service glad i went with u as well. Also i'm sure we will get to the bottom of this
Whistles go Whoooooooooo
What does your valvetrain consist of?
Its an auto, not a dyno queen.
Take it to the track, see how it runs.
This is good advice.
FWIW my LE2 setup dyno'd 360rwhp with an unlocked converter yet runs 11.40's-11.50's at 118-119 MPH in 80+ degree weather. Once I get to the track on a 0 DA day here soon I'm aiming for 11.20's at 120-121. As you can see a dyno is a tuning tool and nothing but. I was sort of discouraged myself when I only put down 360rwhp but the 1/4 mile tells the full story. Good luck.
I understand i have 30lb red svo injectors, delco fuel filter, walbro 255lp fuel pump, am i not getting enough fuel, the injectors should definetly be big enough right?
I don't believe your injectors are big enough. I am running SVO 30's GM 845 cam, LE stage 1 heads 52 mm TB, open headers, stock converter. At a track elevation of 2350, I run 12. 90 @108+. My injector duty cycle at the top of each gear runs 88 to 90 percent. Since you have more motor, I would guess at sea level you are at 100% or greater.
They are fine. There's tons and tons of guys successfully running 30# SVO's with LE2 setups including myself. I don't recall my duty cycle but my tuner who recommended the SVO 30's to me (PCMforless) didn't mention anything bad about the cycle when the car was on the dyno getting tuned. I run in DA ranging from -2000 to +2000 and the car always hauls ass just fine with the 30's and a 255 pump. Even with a high duty cycle the car is only at that high of a duty cycle for a very limited amount of time.
Sounds like what you have works for you and that's what it's all about. I'm happy for you. I wrote the results of what I observed. As far as occuring for only a short period of time, isn't it funny that tire spin, even of short duration, makes such a big difference in ET?
Tire spin is one thing but do you really think that running an injector at 90% for one to three seconds is going to slow a car down? Your still getting the right amount of fuel, know what I mean? If they were beyond maxed out then definitely but I'm not seeing it.
repeated wot runs with nearly maxed/maxed out duty cycles can't be considered a good thing. just an observation.
That was my concern when putting together my setup but I saw so many guys running fine with the 30's that I gave it a shot since the 30's were alot cheaper than 36's at that time. Fast forward a few years and I have not had one single issue running that way.
It's funny because I have been told different things like you don't want to exceed 80% or 85% or even 90% with an injector but then we have Hondas that are set up to run at 100% duty cycle. I think there are alot of differing opinions on that subject.
Here's some food for thought...I know of a guy who runs in a super stock racing class. He actually runs the quickest ET with the smallest injector he can get by with. Why? I have absolutely no idea.
Running at 90% duty cycle won't hurt a thing but I do believe running at 100%+ will. I was at 105% with stock 24s, switched to SVO 30s, duty cycle dropped to 77 and gained performance. Difficult to say exactly how much as Density altitude at my track varies from 3300 to 5000 and as DSA jumps around so does ET. After continuing to tune (and learn) duty cycle is up to 90% with much less horsepower than an LE2 setup should make. If I jumped the cam up to LE2 and ran at sea level, there is no doubt that I would be over 100% duty cycle again. If for no other reason than the injector being constantly on causing increased heat, I believe lowering the duty cycle will increase performance. Just my theory based on my observations. Heck, I even see a Ford win at the track every month or so which proves you can't be right all the time.
21 - 37 of 37 Posts
