Ok, so here is some more info. I am the third owner of this car. PO, Had new trans with shift kit and stall (installed), and new Rear end gears installed. About a week later he had an issue driving home, that the lights and gauges all started to flicker and go out. He thought it was the alternator. He took it out and to a shop, alternator tested fine. So he put that back in. He then took the starter (now he couldn't get it to crank) in and got a new one. Put it on, still no start... He did this 5 times thinking the starters he kept getting were bad (I know it was VATS)
So it sat for 2 years. I come across it, friend of a friend. Thought well the price seems good and I can tinker enough to get myself into trouble. So I purchased it, trailered it, and now she is here. I can hear the fuel pump when I turn the key on.
I had to replace the AC pump as the pulley was locked up. And other than an oil pan gasket leak, she looks to be in good shape. And has all sorts of mods done to it from the first owner. Who ironically is a 5 generation cousin (didn't know at the time until I pull the glove box and found original papers).
Here is the list of things that I know have been done:
K&N cai
Granatelli plenum gms
Granatelli Maf
Big mout throttle body
Long tube header
Edelbrock tower tie
8 over factory injector
Edelbrock front sway bar
Track and swaybar edlebrock
Front to rear chassis edlebrock
Edlebrock springs
Rebuild tranny with shift kit and stall
Rebuilt rear end. New center moser. Rear gear richmond gears 3.73 moser axles
Drilled rotors
Pace setter header
upgraded fuel pump (unsure of how much or from whom)
TAIA
K&N cai
Granatelli Maf
Long tube header
Edelbrock tower tie
Edlebrock springs
Drilled rotors
Pace setter header
TAIA
