Irregular rear end howl on deceleration after bearing replacement
1891 Views 2 Replies 2 Participants Last post by  PRO43
Recently a leaking pinion seal and resulting loss of gear lube caused my pinion bearings to go bad. I had a mechanic replace the bearings (carrier bearings too) and since then it has a somewhat erratic and intermittent howl when decellerating. It gets loudest between 30-35mph and quiets down below 20-25mph. When accelerating and cruising it is very quiet.
The mechanic put in Amzoil Extreme Pressure 75-90 synthetic gear lube but w/o GM additive. He said the gear pattern was ok, the backlash was .005-.006, and he set the pinion bearing preload at 22 in-lbs. With the car on a lift (in neutral with the parking brake on) I found that the yoke seems a little loose, and even has a small amount of end play. Is this normal if the preload is set properly? If it isn't could it be causing the howl?
Sounds like mine haha, I've been driving mine around like that for a year now. I changed my gear oil like a month ago and there were minimal shavings. I think the ten bolts are real whine prone as mine isn't the only f body with a rear end whine.
But if the U-joint/yoke has play in it I'd have him go over it once more. They should be solid or at least I can't wiggle mine
I tightened the pinion nut enough to remove the end play and wobble and the noise is all but gone now.
